[OpenLayers-Trac] Re: [OpenLayers] #3307: add support for WPS
Formats
trac-20090302 at openlayers.org
Mon Jul 18 10:39:09 EDT 2011
#3307: add support for WPS Formats
Reporter: bartvde | Owner: ahocevar
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Format | Version: 2.10
Keywords: | State: Review
Comment(by bartvde):
Replying to [comment:15 ahocevar]:
> Replying to [comment:14 bartvde]:
> > * the change is meant to be able to have complex data without a CDATA
section around it. Deegree does not deal with CDATA.
> This is the part I got. But what I don't get is: how do I get complex
data in a CDATA section after this change?
The same way as before, by specifying "value", it's still the default
behaviour. Only by specifying a "node" attribute which contains an XML
node you will get into the situation without the CDATA section.
> > * I have the same issue, did this work before?
> Yes, it did.
Thanks for clarifying, I'll look into it.
Ticket URL: <http://trac.openlayers.org/ticket/3307#comment:16>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
