[OpenLayers-Trac] [OpenLayers] #3424: Differentiate between TouchEnd and Click in TouchNavigation Control
OpenLayers trac-20090302 at openlayers.org
Thu Jul 21 06:32:34 EDT 2011
 Reporter:  breul             |       Owner:  tschaub
     Type:  feature           |      Status:  new
 Priority:  trivial           |   Milestone:
Component:  Handler.Click     |     Version:  SVN
 Keywords:  event, tap, drag  |       State:
 We have been trying to process click events directly in the
 TouchNavigation control by passing a function to the click handler in the
 TouchNavigation control through the clickHandlerOptions paramter:
 new OpenLayers.Control.TouchNavigation({
                     dragPanOptions: {
                         enableKinetic: true
                     pinchZoom: new
 OpenLayers.Control.PinchZoom({autoActivate: true}),
                     clickHandlerOptions: {
                                handleSingle: function(ev){
                                      //single click code goes here
 The problem we faced was that the handleSingle function is called both on
 single tap events and after drag events, as touchend calls handleSingle in
 the handler.
 We can thus not differentiate between click/tap events and longer drag
 events.
 We fixed this for our project by keeping track of a timestamp set by the
 touchstart event. In touchend that timestamp is evaluated and both the
 timestamp as well as the duration of the touch event from touchstart to
 touchend is passed on in the event object for convenience. We can then
 evaluate this in our hanleSingle function to make sure we are dealing with
 a short tap and not a drag. The attached file contains the changes we are
 using.
 This is of course a quick and dirty fix. Possibly there is already a
 better approach to solve this problem in place.
Ticket URL: <http://trac.openlayers.org/ticket/3424>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
