[OpenLayers-Trac] [OpenLayers] #3350: TouchNavigation and
Navigation Documentation Clarity
trac-20090302 at openlayers.org
Tue Jun 7 15:16:04 EDT 2011
#3350: TouchNavigation and Navigation Documentation Clarity
Reporter: drkludge | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: documentation | Version: 2.10
Keywords: TouchNavigation | State:
It was not clear to me if I had to add both the TouchNavigation and
Navigation controls to the map for touch support in this page
http://docs.openlayers.org/library/mobile.html.
This paragraph from the blog would make a great addition to mobile.html
because it explains the choice of the two navigation controls. Perhaps it
needs to be added to the API docs too.
http://openlayers.org/blog/2011/02/22/mobile-sprint-day-two/
If you’re only targeting touch enabled devices with your mapping
application, you can use the new TouchNavigation control. Our default
Navigation control is mobile ready by default, but you can generate a
smaller build of the library if you’re only handling touch related
navigation.
Ticket URL: <http://trac.openlayers.org/ticket/3350>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
