[OpenLayers-Trac] Re: [OpenLayers] #3307: add support for WPS
Formats
trac-20090302 at openlayers.org
Thu Jun 16 19:13:05 EDT 2011
#3307: add support for WPS Formats
Reporter: bartvde | Owner: ahocevar
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Format | Version: 2.10
Keywords: | State: Review
Comment(by ahocevar):
[attachment:openlayers-3307.patch] adds an example (wps.html), which
currently uses a local GeoServer (should be changed to a public instance
before the patch is committed). The example depends on #3367. Other
changes since [attachment:wps.patch]:
* Added support for ComplexData inputs in WPSExecute. Depends on #3366.
* Use arrays instead of objects for dataInputs in WPSDescribeProcess.
This makes it easy to modify the WPSDescribeProcess::read response and
pass it to WPSExecute::write. There shouldn't be a big performance impact,
since most processes will only have a few dataInputs.
* Use arrays instead of objects for processOutputs in WPSDescribeProcess.
This makes it easier for applications to directly access processOutputs
objects without knowing the object key. I'm not expecting a performance
impact because of the limited number of processOutputs in typical
processes.
* Simplified the structure for dataInputs in WPSDescibeProcess by
removing the inputs object from dataInputs.
Ticket URL: <http://trac.openlayers.org/ticket/3307#comment:7>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
