[OpenLayers-Trac] Re: [OpenLayers] #3355: Make polygons draggable
OpenLayers trac-20090302 at openlayers.org
Thu Jun 16 21:48:23 EDT 2011
  Reporter:  bevan                  |       Owner:
      Type:  bug                    |      Status:  reopened
  Priority:  minor                  |   Milestone:  Maintenance
 Component:  Control.SelectFeature  |     Version:  SVN
Resolution:                         |    Keywords:
     State:  Review                 |
Changes (by bevan):
  * type:  feature => bug
  * state:  Awaiting User Feedback => Review
  * version:  2.10 => SVN
  * component:  Control.DragPan => Control.SelectFeature
  * milestone:  2.12 Release => Maintenance
Comment:
 I worked this out.  The polygons on our map are selectable, with popups.
 The following steps reproduce the issue;
   1. Navigate to [http://openlayers.org/dev/examples/select-feature-
 openpopup.html examples/select-feature-openpopup.html]
   1. Select "''draw polygon''"
   1. Click 2 or more different random points on the map, to begin drawing
 a polygon
   1. Double click one more different random point on the map to close the
 polygon
   1. Select "''navigate''"
   1. Click and drag outside the polygon: Note that the map pans
   1. Click and drag inside the polygon: Note that the map pans
   1. Select "''select polygon on click''"
   * '''Expected behaviour''': The map should pan
   * '''Actual behaviour''': The map does not pan
 It is not clear to me if this is a bug in !OpenLayers or if it is by
 design.
 If it is by design; Are there additional steps that can be taken to
 achieve the desired/expected behaviour?  Please refer me to any such
 documentation or examples.
 Thank you!
Ticket URL: <http://trac.openlayers.org/ticket/3355#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
