[OpenLayers-Trac] [OpenLayers] #3374: Problem with double click to
finish a drawing using IE9
trac-20090302 at openlayers.org
Sun Jun 19 07:24:02 EDT 2011
#3374: Problem with double click to finish a drawing using IE9
Reporter: jorix | Owner: tschaub
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.Path | Version: 2.11 RC1
Keywords: | State:
The problem only occurs in the example http://openlayers.org/dev/examples
/modify-feature.html, all the other examples I've tried works correctly,
oops!? strange...
In this example does not work double-click drawing lines or polygons.
Why?...
I have verified that the patch #3194 fixes the problem, but I do not know
if it's good to fix this.
Tested with IE9 version 9.0.8112.16421 in Vista
Ticket URL: <http://trac.openlayers.org/ticket/3374>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
