[OpenLayers-Trac] Re: [OpenLayers] #3363: Dragging over controls
ends drag sequence
trac-20090302 at openlayers.org
Sun Jun 19 07:56:26 EDT 2011
#3363: Dragging over controls ends drag sequence
Reporter: ahocevar | Owner:
Type: bug | Status: new
Priority: critical | Milestone: 2.11 Release
Component: Handler.Drag | Version: 2.11 RC1
Keywords: regression | State: Review
Changes (by jorix):
* cc: xavier.mamano@… (added)
Comment:
Sounds like a great idea, so I worked a bit again in OL doing some tests
and patchs.
Some observations:
* Default value in the documentation.
* Maintaining the appearance of the cursor outside the map, see #3371 &
#3372
* Error JS in {{{Handler.RegularPolygon}}}, see #3373
* It would be interesting to have {{{documentDrag}}} property in
{{{Handler.Box}}} class.
* Sometimes not detected "mouseout" (dragging vertices using
Control.ModifyFeature). Try out the map to the top using
http://openlayers.org/dev/examples/wfs-snap-split.html, fail enough times
in this example ("erilem" and I saw something like using drawing handlers)
Pending opening a ticket.
Ticket URL: <http://trac.openlayers.org/ticket/3363#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
