[OpenLayers-Trac] Re: [OpenLayers] #3367: Automagically detect
featureType and featureNS
trac-20090302 at openlayers.org
Mon Jun 20 04:06:49 EDT 2011
#3367: Automagically detect featureType and featureNS
Reporter: ahocevar | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Format.GML | Version: 2.11 RC1
Keywords: | State: Commit
Changes (by bartvde):
* state: Review => Commit
Comment:
Hi Andreas, this looks good, 2 minor comments/questions:
* readNode in WFST 1.0 and 1.1 misses "return".
* this is minor and I am not sure what the convention is, but would it
not be cleaner if we filter out the third parameter of readNode before
calling Format.XML's readNode, i.e. return
OpenLayers.Format.XML.prototype.readNode.call(this, [node, obj]);
Relevant tests also pass in IE8 and FF4.
One thing I am still missing from the new Format.GML parser is that we
need a versioned parser in between that will figure out the version (GML2
or GML3) by itself.
As a proof of concept I changed all the Format.GML tests to use GML.v2
however 13 tests are failing in that case, so to replace it would require
some more work, however might be just fixing up the testcases (I see some
small differences with namespaces declaration for xsi etc. missing in the
old Format, it doesn't seem like anything major).
However ofcourse this is out of scope for this ticket. I'll open up
tickets once this gets in.
Ticket URL: <http://trac.openlayers.org/ticket/3367#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
