[OpenLayers-Trac] [OpenLayers] #3381: Permalink produces wrong
result if URL contains an anchor
trac-20090302 at openlayers.org
Wed Jun 22 11:10:19 EDT 2011
#3381: Permalink produces wrong result if URL contains an anchor
Reporter: aviaron | Owner: crschmidt
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Control.Permalink | Version: 2.10
Keywords: permalink hash | State:
If the URL contains an anchor, the Permalink control does not remove it
when producing the permalink url, resulting in an invalid URL.
For example: Adding a Permalink to a page whose URL is
http://example.com/map#foo will produce the following permalink:
http://example.com/map#foo?zoom=4&lat=32.323&lon=34.908&layers=BT
The expected result would have the original anchor appended at the end of
the URL:
http://example.com/map?zoom=4&lat=32.323&lon=34.908&layers=BT#foo
Ticket URL: <http://trac.openlayers.org/ticket/3381>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
