[OpenLayers-Trac] Re: [OpenLayers] #3393: WPSExecute tests are failing in IE8
OpenLayers trac-20090302 at openlayers.org
Thu Jun 30 03:45:56 EDT 2011
  Reporter:  bartvde            |       Owner:  bartvde
      Type:  bug                |      Status:  closed
  Priority:  minor              |   Milestone:  2.12 Release
 Component:  Format.WPSExecute  |     Version:  2.10
Resolution:  fixed              |    Keywords:
     State:                     |
Changes (by bartvde):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 (In [12143]) WPSExecute tests are failing in IE8, the other issue was
 xsi:schemaLocation values in some of the XML snippets containing a TAB,
 non-functional change (closes #3393)
Ticket URL: <http://trac.openlayers.org/ticket/3393#comment:2>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
