[OpenLayers-Trac] Re: [OpenLayers] #3133: click handler should
distinguish between pinches, clicks, and double-clicks
trac-20090302 at openlayers.org
Mon Mar 7 10:21:54 EST 2011
#3133: click handler should distinguish between pinches, clicks, and double-clicks
Reporter: tschaub | Owner: tschaub
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.Click | Version: 2.10
Keywords: mobile | State: Review
Comment(by tschaub):
Basically, the click handler and the pinch handler do not play well
together. This patch is meant to make things better.
Summary of changes:
* tests/Control/TouchNavigation.html - Tests added to confirm that click
handler options can be set via the control's options. By default, the
touch navigation control creates a click handler with a 2 pixel tolerance
for clicks.
* tests/Handler/Click.html - These changes confirm that the new
dblclickTolerance property works as expected and that the existing
pixelTolerance property is used. The tests needed an overhaul to make it
so assertions were not conditionally run.
* lib/OpenLayers/Control/PinchZoom.js - The pinch zoom control needs to
start tracking the current center on pinch start (in case there is no
pinch move before done). Then in the done callback, we only call
setCenter if either the zoom or the center actually changed.
* lib/OpenLayers/Control/TouchNavigation.js - Added support for passing
options to the click handler. By default, the click handler in the touch
navigation control will have a non-zero pixel tolerance. This allows
sloppy fingers to click.
* lib/OpenLayers/Handler/Click.js - The dblclickTolerance property is
added to make it so the double-click callback is not called for clicks
that are very far away from one another. The rest of the event handling
code is refactored to cleanly separate device event listeners from common
handler methods (touch event listeners don't call mouse event listeners,
instead both call common methods). With this change, we can immediately
unregister mouse listeners in a touch environment, preventing duplicate
handling when touch and mouse events propagate. In addition, the
pixelTolerance property is now used to determine if a multi-touch event is
a click.
* lib/OpenLayers/Handler/Pinch.js - The pinch handler needs to prevent
the default behavior of a touchstart (to avoid document scrolling), but it
does not need to stop propagation to other listeners. This allows the
pinch handler and the click handler to work well together regardless of
which is activated first. Because the click handler now properly uses
pixelTolerance and dblclickTolerance, we can safely let touch events be
handled there even when they are part of a pinch.
Ticket URL: <http://trac.openlayers.org/ticket/3133#comment:7>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
