[OpenLayers-Trac] [OpenLayers] #3161: WMS GetFeatureInfo: I and J
should follow axis order
trac-20090302 at openlayers.org
Tue Mar 8 18:34:39 EST 2011
#3161: WMS GetFeatureInfo: I and J should follow axis order
Reporter: bartvde | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Control.WMSGetFeatureInfo | Version: 2.10
Keywords: | State:
7.4.3.7 I, J
The mandatory I and J request parameters are integers that indicate a
point of interest on the map that was produced by the embedded GetMap
request (the “map request part” described in 7.4.3.3). The point (I,J) is
a point in the (i,j) space defined by the Map CS (see 6.7.2). Therefore:
⎯ the value of I shall be between 0 and the maximum value of the i
axis; ⎯ the value of J shall be between 0 and the maximum value of
the j axis; ⎯ the point I=0, J=0 indicates the pixel at the upper
left corner of the map; ⎯ I increases to the right and J increases
downward.
The point (I,J) represents the centre of the indicated pixel. If the value
of I or of J is invalid, the server shall issue a service exception (code
= InvalidPoint).
Ticket URL: <http://trac.openlayers.org/ticket/3161>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
