[OpenLayers-Trac] Re: [OpenLayers] #3133: click handler should
distinguish between pinches, clicks, and double-clicks
trac-20090302 at openlayers.org
Thu Mar 10 20:52:56 EST 2011
#3133: click handler should distinguish between pinches, clicks, and double-clicks
Reporter: tschaub | Owner: tschaub
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.Click | Version: 2.10
Keywords: mobile | State: Commit
Comment(by bbinet):
I also think the patch is good for commit, and the following points are
minor or could be adressed in separate tickets:
* in touchmove method we could check first that this.down is set (as it is
done for touchend method) since we don't need to update this.last if we
haven't received any touchstart.
* currently, when making a double tap which does not
passesDblclickTolerance, neither the click callback nor the dblclick
callback are called. Don't you think the single click callback should
rather get called twice instead?
* as Andreas mentioned, the patch would need to be updated with the last
commits from the sandbox.
Ticket URL: <http://trac.openlayers.org/ticket/3133#comment:11>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
