[OpenLayers-Trac] Re: [OpenLayers] #3046: Popup can't be closed
trac-20090302 at openlayers.org
Fri Mar 11 14:46:13 EST 2011
Reporter: pebXX2346 | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: examples | Version: SVN
Keywords: Popup Strategy BBOX | State: Review
Comment(by pebXX2346):
Well, ...
This bug is '''not''' about the example!
It is a bug in the library. I told you about the example
since that is where e.g. the bug shows up. The url of
the initial report [http://olm.openstreetmap.de/] is another usecase.
I think the lib should handle it. E.g. if the feature
is removed (1), the popup that is owned by the feature should
be removed too. Or there should be code to merge old and new
features, or whatever an architect of OpenLayers may find right.
(1) in olm in zoom the layer is refreshed, that is (i assume)
an indirect remove of the features.
Changing the example where the bug shows is just like
destroying a warning light.
Ticket URL: <http://trac.openlayers.org/ticket/3046#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
