[OpenLayers-Trac] Re: [OpenLayers] #2223: EditingToolbar disappears
when changing baseLayer to Yahoo
trac-20090302 at openlayers.org
Fri Mar 11 16:25:29 EST 2011
#2223: EditingToolbar disappears when changing baseLayer to Yahoo
Reporter: marcjansen | Owner: euzuro
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Control.EditingToolbar | Version: 2.10
Keywords: Yahoo css | State: Review
Comment(by erilem):
Replying to [comment:6 erilem]:
> Replying to [comment:5 jorix]:
> > I have not able to test in local (no key to Yahoo). Works correctly by
changing the CSS class {{{olControlEditingToolbar}}} with FF+firebug.
> > Please review.
> Thanks for the patch.
> Some information: the problem exists only with Yahoo Maps because the
YMap constructor changes the layer div from {{{absolute}}} to
{{{relative}}}. We can also note that the pane div of the Yahoo layer is
also below the layer div, I'm not sure whether that's a problem.
See [attachment:patch-2223-A0.diff], which also fixes the issue reported
by this ticket. This patch just aims to show how the issue relates to
YMap, Xavier's patch is the one to be committed.
> Anyway, your patch looks good to me, but I'd also remove
{{{float:right}}}, which doesn't make sense since the panel is absolutely
positioned. I'll commit your patch if you agree with that.
Ticket URL: <http://trac.openlayers.org/ticket/2223#comment:7>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
