[OpenLayers-Trac] [OpenLayers] #3182: Problem with SLDSelect Control when used on projected map.
OpenLayers trac-20090302 at openlayers.org
Sun Mar 20 17:06:30 EDT 2011
 Reporter:  scaddenp           |       Owner:  bartvde
     Type:  bug                |      Status:  new
 Priority:  major              |   Milestone:  2.11 Release
Component:  Control.SLDSelect  |     Version:  2.10
 Keywords:                     |       State:
 The suspicion is that polygon definition in the filter may need an SRS
 name. (WFS filter calls include the SRS in the polygon definition and the
 WFS filter works).
 Step to reproduce:
 Take the SLDSelect example code from
 Change map options to projection 900913, maxExtent to google extent
 transform the centre lat/long to 900913 too.
 Add a google layer and remove allOverlays from map options.
 Attached is a version of the code, but the script location have been
 changed to work with my server.
Ticket URL: <http://trac.openlayers.org/ticket/3182>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
