[OpenLayers-Trac] Re: [OpenLayers] #3182: Problem with SLDSelect
Control when used on projected map.
trac-20090302 at openlayers.org
Tue Mar 22 06:08:49 EDT 2011
#3182: Problem with SLDSelect Control when used on projected map.
Reporter: scaddenp | Owner: bartvde
Type: bug | Status: assigned
Priority: major | Milestone: 2.11 Release
Component: Control.SLDSelect | Version: 2.10
Keywords: | State:
Comment(by ahocevar):
bartvde: My comment was just about what GeoServer does. The SLD
Application Profile of the WMS spec (OGC 05-078) says that Filter Encoding
1.1 is used, which again says in section 8.3: "If the literal geometry SRS
matches one of the <DefaultSRS> values or <OtherSRS> of the queried
feature type, then the WFS is free to transform either the literal
geometry or feature geometries for purposes of processing the query only.
Any matching features must be returned in the requested and supported SRS.
If the literal geometry SRS is unspecified, then the literal geometry SRS
shall be interpreted to be equivalent to the <DefaultSRS> of the queried
feature type."
I'd interpret this as if you are right. GeoServer should respect srsName
in the filters, even if part of an SLD/WMS request.
Ticket URL: <http://trac.openlayers.org/ticket/3182#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
