[OpenLayers-Trac] Re: [OpenLayers] #3168: FramedCloudPopup has
offset
trac-20090302 at openlayers.org
Sat Mar 26 09:58:45 EDT 2011
#3168: FramedCloudPopup has offset
Reporter: pebXX2346 | Owner: euzuro
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Popup | Version: 2.10
Keywords: position | State:
Comment(by pebXX2346):
The offset goes away if one adds those two lines at the end
of calculateNewPx in Popup.Anchored
newPx.y += top? -this.anchor.offset.y:0; //flicker if on top and hovering
newPx.x += (left? -1:1)*this.anchor.offset.x;
'''But'''
1 as noted the popup flickers/flashes if it is on top (only in 'hover
mode')
2 it is nearly perfectly aligned at lonlat, but looks a bit strange
if the popup is on top since the cloud embraces the marker (see attached
image)
Nr. 2 seems to be ok, one have a look at this.
Nr.1 is bad, maybe comes from: popup hides marker, marker gets
mouseout, hides popup, gets mouseover and the hover process restarts:
flashing loop.
It works if one 'clicks' (or however the popup-show is triggered)
on the marker.
Ticket URL: <http://trac.openlayers.org/ticket/3168#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
