[OpenLayers-Trac] [OpenLayers] #3217: Click handler - mouse
listeners may be re-registered
trac-20090302 at openlayers.org
Wed Mar 30 12:20:47 EDT 2011
#3217: Click handler - mouse listeners may be re-registered
Reporter: erilem | Owner: tschaub
Type: bug | Status: new
Priority: major | Milestone: 2.11 Release
Component: Handler.Click | Version: 2.10
Keywords: | State:
Currently the {{{touchstart}}} function of the click handler unregisters
the mouse listeners when it is executed the first time:
touchstart: function(evt) {
if(!this.touch) {
this.touch = true;
this.unregisterMouseListeners();
The problem is that the mouse listeners will be re-registered if the
handler is deactivated and re-activated, and {{{touchstart}}} won't
unregister them again because of the {{{touch}}} flag.
We could unconditionally call {{{unregisterMouseListeners}}} in
{{{touchstart}}}, but we would incur a for loop over every mouse listener
on each {{{touchstart}}}, which doesn't sound too good to me.
Another solution involves having {{{touchstart}}} set {{{touch}}} to true,
and immediately returning from the mouse listeners when {{{touch}}} is
true. E.g.
mousedown: function(evt) {
if(this.true) {
return;
I think that's what we were using before we introduced this
{{{unregisterMouseListeners}}} function.
Ticket URL: <http://trac.openlayers.org/ticket/3217>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
