[OpenLayers-Trac] Re: [OpenLayers] #3194: Problem with double click
to finish a
drawing using IE6 (was: Problem with double click to finish a
drawing using IE6 (and IE8 without !DOCTYPE))
trac-20090302 at openlayers.org
Thu Mar 31 13:22:07 EDT 2011
#3194: Problem with double click to finish a drawing using IE6
Reporter: jorix | Owner: tschaub
Type: bug | Status: new
Priority: major | Milestone: 2.11 Release
Component: Handler.Path | Version: SVN
Keywords: | State: Awaiting User Feedback
Comment(by jorix):
Replying to [comment:7 erilem]:
> Hi Xavier.
> First of all, I don't understand what you mean by "with further
improvement: pan while drawing" above. Do you mean the problem is more
easily reproducible in trunk than in 2.10 because of the "pan draw" patch?
Yes
I tested doubleclick with IE6 using "examples/draw-feature.html" with
"trunk" and "2.10". With "2.10" it costs to make a double click, but in
the "trunk" I have not done any double-click (path and polygons)
Regarding IE8, rarely fails and are more subjective differences in
misbehavior double click using "trunk" or "2.10"
> Now some information:
> I could effectively reproduce the issue in IE8 using the measure.html
example. I'm also observing that the size of the map div changes while
drawing! I'd tend to think the "double-click to finalize drawing" issue is
related to that.
> And actually, you don't have to activate drawing to see the map div
changing in size: select "navigate", and do sequences like this: "pan the
map, leave the map div, re-enter the map div, ...". You should see the map
shrinking and enlarging.
> By adding {{{<!DOCTYPE>}}} to the page the problems effectively go away.
> The map changing in size on sequences like "leaving the map div,
entering the map div, panning, ..." can also be observed on other
examples, {{{draw-feature.html}}} for example.
Yes, I know this effect. This effect disappears using {{{<div id="map"
style="border: 0 solid #000" class="smallmap"></div>}}} or using
{{{<!DOCTYPE>}}}, even using IE6. But the problem of double click using
IE6 on the trunk does not disappear.
> At this point I don't know whether this is a regression.
Ok, IE6 is increasingly residual.
Ticket URL: <http://trac.openlayers.org/ticket/3194#comment:8>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
