[OpenLayers-Trac] Re: [OpenLayers] #3288: Adding vector layer to invisible map throw an error
OpenLayers trac-20090302 at openlayers.org
Wed May 4 01:07:37 EDT 2011
 Reporter:  jlacroix  |       Owner:
     Type:  bug       |      Status:  new
 Priority:  minor     |   Milestone:  2.12 Release
Component:  Renderer  |     Version:  2.10
 Keywords:            |       State:  Review
Comment(by erilem):
 My review comments:
  * In {{{Renderer.setSize}}} you could do {{{this.size = size &&
 size.clone();}}}
  * I'd actually rather not change the base class and have the specific
 classes' {{{setSize}}} functions return right away if !size, not to call
 the parent when it's not necessary
  * I'd rather put the new test in the renderer test files, that
 duplicating it for all the renderers for which the problem triggers (all
 maybe?)
  * I think the test should go in its own function, and have a link to this
 ticket
  * In the test you could check that the renderer size, as opposed to the
 map size, has actually changed
 Hope these comments make sense.
Ticket URL: <http://trac.openlayers.org/ticket/3288#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
