[OpenLayers-Trac] [OpenLayers] #3289: dimensions of map div change
in IE
trac-20090302 at openlayers.org
Wed May 4 02:24:23 EDT 2011
#3289: dimensions of map div change in IE
Reporter: erilem | Owner:
Type: bug | Status: new
Priority: major | Milestone: 2.12 Release
Component: Map | Version: 2.10
Keywords: | State:
As discussed in #3194 the dimensions of the map div change while
interacting with the map in IE.
The map changing in size on sequences like "leaving the map div, entering
the map div, panning, ..." can also be observed on other examples, draw-
feature.html for example.
Adding {{{<!DOCTYPE>}}} to the page makes the problem go away. Adding
{{{style="border: 0 solid #000"}}} also makes the problem go away.
It would be good to know more about this problem, and possibly come with
some code in !OpenLayers to address it.
Ticket URL: <http://trac.openlayers.org/ticket/3289>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
