[OpenLayers-Trac] [OpenLayers] #3291: Refresh Vector Layer changing
featureType
trac-20090302 at openlayers.org
Wed May 4 09:49:43 EDT 2011
#3291: Refresh Vector Layer changing featureType
Reporter: user999 | Owner: tschaub
Type: bug | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Protocol.WFS | Version: SVN
Keywords: featureType | State:
I have to refresh a Vector Layer added to my map. In particular, I want to
change the featureType of that Vector Layer (WFS) so that I can switch the
different layers hosted on Geoserver. To do this task, I try a lot of case
and the only one that works is the following:
function updt() {
map.layers[2].protocol.setFeatureType("3itemsview");
map.layers[2].refresh({featureType: "3itemsview" });
Why I must use both that operation? If I use only one comand or the first
one and
map.layers[2].refresh({force: true});
it doesn't work.
Is not logic set the same field twice.
Thanks.
Best reguard,
Yuri
Ticket URL: <http://trac.openlayers.org/ticket/3291>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
