[OpenLayers-Trac] Re: [OpenLayers] #3268: EditingToolbar: It shows
no control active by default.
trac-20090302 at openlayers.org
Mon May 9 15:27:51 EDT 2011
#3268: EditingToolbar: It shows no control active by default.
Reporter: jorix | Owner:
Type: bug | Status: new
Priority: trivial | Milestone: 2.11 Release
Component: Control.EditingToolbar | Version: 2.10
Keywords: | State: Review
Comment(by erilem):
Replying to [comment:4 jorix]:
> Replying to [comment:3 erilem]:
> > Thanks for catching this and the patch jorix. It looks good. Would you
mind adding a test function that checks that the first control is activate
after the panel is added to the map?
> Yes, I will prepare tests[[BR]]
> (It's almost just an example ;-), and the file
"tests/Control/EditingToolbar.html" does not exist, so no tests suggested)
Did I say examples shouldn't have tests? :-)
Ticket URL: <http://trac.openlayers.org/ticket/3268#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
