[OpenLayers-Trac] Re: [OpenLayers] #3194: Problem with double click to finish a drawing using IE6
OpenLayers trac-20090302 at openlayers.org
Thu May 12 16:42:26 EDT 2011
 Reporter:  jorix         |       Owner:  tschaub
     Type:  bug           |      Status:  new
 Priority:  major         |   Milestone:  2.11 Release
Component:  Handler.Path  |     Version:  SVN
 Keywords:                |       State:  Needs More Work
Changes (by jorix):
  * state:  Awaiting User Feedback => Needs More Work
Comment:
 With IE6 the problem is that pressing double click to finish drawing the
 sequence of events is the following: {{{mousedown}}}, {{{mouseup}}} and
 {{{mouseup}}}!. Yes disappears second {{{mousedown}}} and {{{dblclick}}}.
 The patch proposes emulate the double click, like the double tap is
 emulated.
 This simplifies the Measure control no longer need timer :-)
 All I have done testing with IE6, IE8 and FF3.16, and working correctly
 But, logically a lot of tests stop working :-(([[BR]]
 Before further work on this I thought it appropriate to present the
 operational side of the patch.
Ticket URL: <http://trac.openlayers.org/ticket/3194#comment:9>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
