[OpenLayers-Trac] Re: [OpenLayers] #3306: preremovelayer event
trac-20090302 at openlayers.org
Fri May 20 08:22:30 EDT 2011
Reporter: mosesonline | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Map | Version: SVN
Keywords: | State: Needs More Work
Comment(by marcjansen):
I had no time to check the second patch (regarding the point in time when
you trigger the new event).
As for the tests: you should at least test,
* whether your event is fired
* and whether it behaves correctly (depending on the return value)
For this you have to create new tests.
Ticket URL: <http://trac.openlayers.org/ticket/3306#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
