[OpenLayers-Trac] [OpenLayers] #3308: Line: 140 Error:
'this.blocks.length' is null
or not an object (on destroy at at Framed.js)
trac-20090302 at openlayers.org
Fri May 20 09:17:29 EDT 2011
#3308: Line: 140 Error: 'this.blocks.length' is null or not an object (on
Reporter: flexer | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: | State:
Somtimes this error occurred:
- that is at Framed.js:
destroy: function() {
for(var i = 0; i < this.blocks.length; i++) {
this.blocks = null;
I think the error occurred on second "destroy" function call.
If two times call of "destroy" is a valid operation
(seems it should be a valid operation)
then the "for.." operation should check if this.blocks is null.
Ticket URL: <http://trac.openlayers.org/ticket/3308>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
