[OpenLayers-Trac] [OpenLayers] #3310: DrawFeature control in
freehand mode produces invalid geometries
trac-20090302 at openlayers.org
Fri May 20 10:58:26 EDT 2011
#3310: DrawFeature control in freehand mode produces invalid geometries
Reporter: rayd | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Control.DrawFeature | Version: 2.10
Keywords: geometry | State:
To test this out I used the the draw feature example here:
http://dev.openlayers.org/releases/OpenLayers-2.10/examples/draw-
feature.html
Use a DrawFeature control in freehand mode with a Path handler to draw a
line. Instead of dragging the mouse, just click once -- you will get a
feature with a LINESTRING geometry with only one point. You can use a tool
like Firebug to inspect the created features. Similarly, use a DrawFeature
control in freehand mode with a Polygon handler. Just click once on the
map, and you will get a feature with a POLYGON geometry with a LinearRing
geometry with only two points. This shouldn't happen since those are
technically invalid geometries.
I would think in this situation we're just better off not adding the
feature to the layer in the first place.
Ticket URL: <http://trac.openlayers.org/ticket/3310>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
