[OpenLayers-Trac] [OpenLayers] #3313: GeoJSON strings should not
include internal feature ids
trac-20090302 at openlayers.org
Mon May 23 09:03:37 EDT 2011
#3313: GeoJSON strings should not include internal feature ids
Reporter: erilem | Owner: tschaub
Type: bug | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Format.GeoJSON | Version: 2.10
Keywords: | State:
Currently the GeoJSON format does this when serializing a feature:
"id": feature.fid == null ? feature.id : feature.fid,
So if the feature object has no fid, meaning it is not known outside
!OpenLayers, then we set {{{id}}} to {{{feature.id}}} in the GeoJSON
string.
We should not. !OpenLayers internal ids shouldn't be written into the
GeoJSON string, as it may confuse the server.
In !MapFish we'd indeed like to determine whether the feature is being
updated or created, based on whether {{{id}}} is set or not in the GeoJSON
string. Currently !MapFish considers it is a CREATE operation if the id is
a string, which is far from ideal.
Ticket URL: <http://trac.openlayers.org/ticket/3313>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
