[OpenLayers-Trac] Re: [OpenLayers] #3315: Problem with geometry
handlers - doesn't stop showing a point under the cursor
trac-20090302 at openlayers.org
Tue May 24 05:07:38 EDT 2011
#3315: Problem with geometry handlers - doesn't stop showing a point under the
cursor
Reporter: mgleahy | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.Point | Version: 2.11 RC1
Keywords: | State:
Comment(by erilem):
I'm failing to reproduce the issue. I set "immediate" to true in the
measure control, and added a "measurepartial" listener. But after double-
click to finish a measurement, I don't see my "measurepartial" listener
being called when moving the mouse. Could you please modify the
measure.html example to help me understand where the problem is? Thanks.
Ticket URL: <http://trac.openlayers.org/ticket/3315#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
