[OpenLayers-Trac] Re: [OpenLayers] #3315: Problem with geometry
handlers - doesn't stop showing a point under the cursor
trac-20090302 at openlayers.org
Wed May 25 10:40:07 EDT 2011
#3315: Problem with geometry handlers - doesn't stop showing a point under the
cursor
Reporter: mgleahy | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.Point | Version: 2.11 RC1
Keywords: | State:
Comment(by jorix):
Replying to [comment:6 erilem]:
> > @erilen: The line
[http://trac.osgeo.org/openlayers/browser/trunk/openlayers/lib/OpenLayers/Handler/Path.js?rev=11962#L344
344 of Path.js] should be {{{this.modifyFeature(evt.xy,
}}}'''true'''{{{);}}}?
> Or {{{!!this.lastUp}}}, no?
Yes, you are right, before the first point must be false.
But there is a problem with {{{!!this.lastUp}}} using freehand (in
{{{down}}} and {{{move}}} methods):
* use the example [http://openlayers.org/dev/examples/measure.html
measure.html] selecting "use immediate measures"
* start freehand
* release the shift key
* move, oops! the immediate measure does not change.
* continue freehand
* move, ok! now works
It's a minor problem which I have not opened ticket. This problem and
#3310 make me think it would be good to reintroduce "handler.drawing" (and
it has the advantage of causing less trouble adapting to users, eg: this
ticket)
What is your opinion?
Ticket URL: <http://trac.openlayers.org/ticket/3315#comment:7>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
