[OpenLayers-Trac] [OpenLayers] #3319: Handler.Path: Problem with
modify callback in drawing parameter.
trac-20090302 at openlayers.org
Thu May 26 13:20:51 EDT 2011
#3319: Handler.Path: Problem with modify callback in drawing parameter.
Reporter: jorix | Owner: tschaub
Type: bug | Status: new
Priority: trivial | Milestone: 2.11 Release
Component: Handler.Path | Version: 2.11 RC1
Keywords: | State:
There is a problem with {{{"modify"}}} callback in {{{drawing}}} parameter
using freehand (in {{{down}}} and {{{move}}} methods)
Starting freehand, and continuing in normal mode all the moves before the
next point call "modify" callback with the drawing parameter to false.
Try:
* use the example [http://openlayers.org/dev/examples/measure.html
measure.html] selecting "use immediate measures"
* start freehand
* release the shift key
* move, oops! the immediate measure does not change.
* continue freehand
* move, ok! now works
Ticket URL: <http://trac.openlayers.org/ticket/3319>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
