[OpenLayers-Trac] [OpenLayers] #3327: Error in
OpenLayers.Handler.Path.activate using SVG2 rendered
trac-20090302 at openlayers.org
Fri May 27 06:04:58 EDT 2011
#3327: Error in OpenLayers.Handler.Path.activate using SVG2 rendered
Reporter: vrifino | Owner: ahocevar
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Renderer.SVG | Version: 2.11 RC1
Keywords: SVG2 | State:
I'm testing SVG2 renderer in my application. I enable it with this code
OpenLayers.Layer.Vector.prototype.renderers = ["SVG2", "VML", "Canvas"];
Then I create an Openlayers.Control.Measure with a custom handler
OpenLayers.Handler.Path, {
persist: true,
handlerOptions: {
layerOptions: {styleMap: styleMap}
When I activate the control, I get this error in the console
Error: Problem parsing points="NaN,NaN"
Same problem with an OpenLayers.Handler.Polygon.
The problem doesn't show if I use the default SVG renderer.
Vito
Ticket URL: <http://trac.openlayers.org/ticket/3327>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
