[OpenLayers-Trac] [OpenLayers] #3328: Optimization on vector layer
trac-20090302 at openlayers.org
Fri May 27 06:56:44 EDT 2011
Reporter: mosesonline | Owner: crschmidt
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Layer.Vector | Version: 2.10
Keywords: | State: Review
Some weeks ago I found a bug with the SVG2/NG
renderer([http://trac.osgeo.org/openlayers/ticket/3257]). Now, while made
the zooming work, I noticed some improvement potential in the moveTo
function of OpenLayer.Layer.Vector class.[[BR]]
The most is removing of variables which are used only once. Such variables
are great for debugging but not needed.[[BR]]
The second is the last loop to draw the features. It writes
renderer.locked attribute in every loop and tries to avoid
this.features.length-1 in the for-loop header but does this in the next
line with the ''len'' variable, which both is not needed when you have a
''lastIdx'' variable.[[BR]]
This aren't big changes, but I think it's hot code so optimization should
be done where possible:)[[BR]]
I made a patch with this changes, but there also the "fix" for the ticket
3257 in it, I hope it doesn't bother.
Ticket URL: <http://trac.openlayers.org/ticket/3328>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
