[OpenLayers-Trac] [OpenLayers] #3329: Handler.Path: The drawing starts after a drag
OpenLayers trac-20090302 at openlayers.org
Fri May 27 18:36:52 EDT 2011
 Reporter:  jorix         |       Owner:  tschaub
     Type:  bug           |      Status:  new
 Priority:  trivial       |   Milestone:  2.11 Release
Component:  Handler.Path  |     Version:  2.11 RC1
 Keywords:                |       State:
 When the drag ends at the same point where it started, the drawing begins.
 If it was drawing a point is added.
 It is very unlikely happen. I found writing the code tests for #3323. The
 last test of {{{function test_persist_freehand}}} should be:
 {{{498:     t.ok(feature3.layer == null, "d) feature3 }}}'''not'''{{{
 destroyed");}}}
 You can reproduce using "measure distance" on
 http://openlayers.org/dev/examples/measure.html and start a drag from a
 corner, and ending on the same corner (taking care of pixels there are
 only 5 of tolerance ;-)
Ticket URL: <http://trac.openlayers.org/ticket/3329>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
