[OpenLayers-Trac] Re: [OpenLayers] #3257: NG renderer does not recalculate feature styles on zoom change
OpenLayers trac-20090302 at openlayers.org
Mon May 30 09:11:27 EDT 2011
 Reporter:  ahocevar     |       Owner:  ahocevar
     Type:  bug          |      Status:  new
 Priority:  minor        |   Milestone:  2.12 Release
Component:  Renderer.NG  |     Version:  SVN
 Keywords:               |       State:  Review
Comment(by mosesonline):
 Ok, it seems to work fine in FF 4.0.1 and Chrome 13. But I have a problem
 with our customized SVG2 renderer, that's why I'm so late with an answer,
 for which I don't know if it is your patch or our renderer. It works fine
 with most of our data types but not with the most important one.[[BR]]
 Our modification turns font-tags in labels to tspan's, but with the patch
 after zoom the labels stay at the same size till I turn visibility off and
 on. The "funny" thing is that color works fine, but the font-size
 attribute of the inner tspan elements aren't changed. The function is
 processed with the right font-size set on the tag but the resulting tag
 (according to firebug/chrome) doesn't change.[[BR]]
 But with other data and the example the patch works. Nice solution by the
 way, I thought about a similar, but this looks clever and no changes in
 current code are necessary(expect the fix of our probable error:)).
Ticket URL: <http://trac.openlayers.org/ticket/3257#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
