[OpenLayers-Trac] Re: [OpenLayers] #3323: Handler.Path: Not always
clean the persistence
trac-20090302 at openlayers.org
Mon May 30 11:18:18 EDT 2011
#3323: Handler.Path: Not always clean the persistence
Reporter: jorix | Owner: tschaub
Type: bug | Status: new
Priority: trivial | Milestone: 2.11 Release
Component: Handler.Path | Version: 2.11 RC1
Keywords: | State: Review
Comment(by jorix):
Replying to [comment:3 crschmidt]:
> This doesn't seem like it is a regression from 2.10. Can you confirm or
deny that? If it's not, I'm likely to kick this to 2.12.
I confirm using 2.10 works ok. It's a new bug from 2.11
Note #3319 (now changed to 2.12 by crschmidt) is also a new bug from 2.11,
and I think the fix is easy after having applied this patch (only needs to
be changed {{{!!this.lastUp}}} by {{{this.drawing}}} in {{{down}}} and
{{{move}}} methods)
Ticket URL: <http://trac.openlayers.org/ticket/3323#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
