[OpenLayers-Trac] Re: [OpenLayers] #3327: Error in
OpenLayers.Handler.Path.activate using SVG2 rendered
trac-20090302 at openlayers.org
Tue May 31 08:54:44 EDT 2011
#3327: Error in OpenLayers.Handler.Path.activate using SVG2 rendered
Reporter: vrifino | Owner: erilem
Type: bug | Status: new
Priority: major | Milestone: 2.11 Release
Component: Renderer.SVG | Version: 2.11 RC1
Keywords: SVG2 | State: Needs More Work
Comment(by jorix):
Replying to [comment:3 erilem]:
> I started working on that. I think we need to modify the drawing
handlers, not to add the feature when the control is activated.
I do not know if you can help see #3321, I know that is not the same.
Ticket URL: <http://trac.openlayers.org/ticket/3327#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
