[OpenLayers-Trac] [OpenLayers] #3567: Map: Bug due to #3531
trac-20090302 at openlayers.org
Fri Nov 4 20:08:52 EDT 2011
Reporter: jorix | Owner:
Type: bug | Status: new
Priority: major | Milestone: 2.12 Release
Component: Map | Version: 2.11
Keywords: | State:
After applying #3531 the function
{{{OpenLayers.Util.getRenderedDimensions}}} does not work properly.
If {{{options.containerElemen = map.layerContainerDiv}}}, then returns
size with {{{w=100}}} due to
https://github.com/openlayers/openlayers/commit/ded64c00d42317ad0bac32a5e62f8597068c0bc2#diff-8.
Can see the problem with popups when {{{popup.autoSize = true}}}. The
width is {{{100px}}} regardless of content.
See the problem in {{{example/sundials-spherical-mercator.html}}} using
trunk !GitHub [[BR]]
(but not using {{{http://openlayers.org/dev/}}}, however using
{{{http://openlayers.org/dev/lib}}} did observe the problem -- should have
the same behavior but the compressed code does not match the source files,
oops! --)
Ticket URL: <http://trac.openlayers.org/ticket/3567>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
