[OpenLayers-Trac] Re: [OpenLayers] #3578: Need a way to get the
coordinates of the click on vector features/layers
trac-20090302 at openlayers.org
Tue Nov 22 18:13:13 EST 2011
#3578: Need a way to get the coordinates of the click on vector features/layers
Reporter: vishcious | Owner: tschaub
Type: feature | Status: reopened
Priority: minor | Milestone: 2.12 Release
Component: Control.SelectFeature | Version: 2.11
Resolution: | Keywords:
State: Review |
Comment(by jorix):
Replying to [comment:6 ahocevar]:
> Solution here: https://github.com/openlayers/openlayers/pull/67 - no
need to set {{{OpenLayers.Events.prototype.includeXY = true}}}.
I was working on extending your patch to work with hover+highlightOnly and
I have seen that there is a hidden bug.
Why?: If you add the listener {{{beforefeatureselected}}}, the event
{{{featureselected}}} has {{{evt.type ="beforefeatureselected"}}}. See:
[http://trac.osgeo.org/openlayers/browser/trunk/openlayers/lib/OpenLayers/Events.js#L753
Events.js - Line 753 in triggerEvent method]
See the problem with this change [attachment:3578-bug-more-test.patch 3578
-bug-more-test.patch]. then the test {{{"featureselected: evt.type is
proper set."}}} fails (Without pull/67 this test works)
Note: In this case it is not what is the best way to present the problem,
a pull requesst in ahocevar/openlayers?
Ticket URL: <http://trac.openlayers.org/ticket/3578#comment:7>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
