[OpenLayers-Trac] [OpenLayers] #3585: Click to add feature (circle)
-> center is not quite where clicked
trac-20090302 at openlayers.org
Mon Nov 28 04:58:04 EST 2011
#3585: Click to add feature (circle) -> center is not quite where clicked
Reporter: DottedAlex | Owner: tschaub
Type: bug | Status: new
Priority: trivial | Milestone: 2.12 Release
Component: Handler.Point | Version: 2.11
Keywords: | State:
FYI: I've filed this under Handler.Point but it applies to all the other
feature handlers too.
Using OpenLayers.Control.DrawFeature with OpenLayers.Handler.Point and
circle as symbolizer the circle is never quite drawn where clicked (It's
out by one pixel).
I've followed this through the code and it seems the renderers use the top
left of the clicked pixel as center so circles always appear 'off center'.
Solution is farily simple: Alter createFeature in OpenLayers.Handler.Point
so that 0.5 is added to the clicked location which causes the middle of
the pixel to be used instead:
createFeature: function(pixel) {
pixel = pixel.add(0.5,0.5);
var lonlat = this.map.getLonLatFromPixel(pixel);
this.point = new OpenLayers.Feature.Vector(
new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat)
Ticket URL: <http://trac.openlayers.org/ticket/3585>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
