[OpenLayers-Trac] [OpenLayers] #3588: Problems with the display in
IE
trac-20090302 at openlayers.org
Mon Nov 28 17:03:38 EST 2011
#3588: Problems with the display in IE
Reporter: pinosiciliano | Owner: tschaub
Type: bug | Status: new
Priority: major | Milestone: 2.12 Release
Component: Format.GeoJSON | Version: 2.11
Keywords: | State:
Hi there,
I'm Giuseppe and I'm doing a project using OpenLayers.
But I encountered a problem: works fine with IE9 but not work with IE8.
This is link to my project:
http://www.ibasblog.it/confimap (/index.html)
work fine with FF, IE9.
With IE8 loads slowly, the pan does not work and you can not interact with
the points of the map.
This result from debbugging tool of IE9 with IE8 compatibility mode:
SCRIPT1014: Carattere non valido
OpenLayers.js, Riga 290 Carattere 754
SCRIPT5007: Impossibile ottenere il valore della proprietà
'selectedFeatures': oggetto nullo o non definito
OpenLayers.js, Riga 1437 Carattere 210
'getFeatureFromEvent': oggetto nullo o non definito
OpenLayers.js, Riga 1430 Carattere 406
I use file format GeoJSON.
Can you help?
Thanks a lot.
Best Regards,
Giuseppe Lo Burgio
Ticket URL: <http://trac.openlayers.org/ticket/3588>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
