[OpenLayers-Trac] [OpenLayers] #3541: Bug with document drag in
Firefox with scrolled down pages.
trac-20090302 at openlayers.org
Fri Oct 7 04:05:46 EDT 2011
#3541: Bug with document drag in Firefox with scrolled down pages.
Reporter: brage | Owner:
Type: feature | Status: new
Priority: major | Milestone: 2.12 Release
Component: general | Version: 2.11
Keywords: | State:
If you use document drag in Firefox, and the page is scrolled down, the
map will appear to jump erratically when you drag the cursor outside the
map viewport.
To reproduce the error, use Firefox and go to
http://www.openlayers.org/dev/examples/document-drag.html. Zoom in a bit,
resize the window to make vertical scroll bars appear, and scroll down a
bit. When you drag outside the map, the map will now pan upwards.
The coordinates used to determine map position is apparently relative to
the visible browser window, not relative to the page.
(Tested with Firefox 6 and 7.)
Ticket URL: <http://trac.openlayers.org/ticket/3541>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
