[OpenLayers-Trac] [OpenLayers] #3545: Fix failing tests (Layer.Vector::getFeatureFromEvent)
OpenLayers trac-20090302 at openlayers.org
Sun Oct 9 10:10:24 EDT 2011
 Reporter:  marcjansen    |       Owner:  crschmidt
     Type:  bug           |      Status:  new
 Priority:  minor         |   Milestone:  2.12 Release
Component:  Layer.Vector  |     Version:  2.11
 Keywords:                |       State:
 The tests
   * Layer/PointTrack.html, test_Layer_PointTrack_destroy
   * Layer/Vector.html, test_Layer_Vector_destroy
 currently fail because of an exception in
 Layer.Vector::getFeatureFromEvent: "getFeatureFromEvent called on layer
 with no renderer. This usually means you destroyed a layer, but not some
 handler which is associated with it."
 See
 https://github.com/openlayers/openlayers/blob/master/lib/OpenLayers/Layer/Vector.js#L829
Ticket URL: <http://trac.openlayers.org/ticket/3545>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
