[OpenLayers-Trac] Re: [OpenLayers] #3531: add continuous zooming support for tiled layers
OpenLayers trac-20090302 at openlayers.org
Mon Oct 24 16:23:25 EDT 2011
  Reporter:  erilem      |       Owner:  elemoine
      Type:  feature     |      Status:  closed
  Priority:  major       |   Milestone:  2.12 Release
 Component:  Layer.Grid  |     Version:  2.11
Resolution:  fixed       |    Keywords:
     State:  Commit      |
Comment(by erilem):
 Replying to [comment:8 scaddenp]:
 > My case is map resolutions from 1 through to 21, but I have
 serverResolutions from [3-11]. The patch works well when map zoom from 12
 to 21. (just resizes the 11 level images). However, going to resolution 1
 or 2 causes the exception.
 Indeed.
 > As I understand your proposal, it would call and resize the tiles of
 resolution 3?
 Yes.
 > I am okay with that  but possibly a lot of server requests from that
 route. I would rather the layer dropped out at map resolutions < 3.
 Can't you set a {{{minResolution}}} value in your later for that?
 > I have currently coded my own getURL for TMS tile sets that redirects to
 a blank tile in this case.
Ticket URL: <http://trac.openlayers.org/ticket/3531#comment:9>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
