[OpenLayers-Trac] Re: [OpenLayers] #3484: setcenter is not being
	nice....
    trac-20090302 at openlayers.org
    Thu Sep  1 03:12:20 EDT 2011
#3484: setcenter is not being nice....
  Reporter:  cpugenuis               |       Owner:
      Type:  bug                     |      Status:  closed
  Priority:  trivial                 |   Milestone:
 Component:  Map                     |     Version:  2.10
Resolution:  worksforme              |    Keywords:
     State:  Awaiting User Feedback  |
Changes (by ckreuzbe):
  * status:  new => closed
  * state:  => Awaiting User Feedback
  * version:  2.11 RC3 => 2.10
  * resolution:  => worksforme
  * milestone:  2.12 Release =>
Comment:
 set center is working fine, just try using coordinates that actually exist
 e.g. 39/85 would work, while 39/89 is already outside of the maximum
 displayed extent of google maps, as you can see in the following example,
 using your code (you will see a gray area above):
 <html> <head> <title>OpenLayers Example</title> <meta charset='utf-8' />
     <script src="
 http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAKkhwo33u311L5mz
 --Y7BEBTwprBKjA_n3Ly6yGptNtUzx2EkQRQ7CYjqtnwqpFOZmWe_M5mJHK4T4g"></script>
 <script src='http://openlayers.org/api/OpenLayers.js'></script> </head>
 <body>
         <div style="width:100%; height:100%" id="map"></div> <script
 type="text/javascript"> var map = new OpenLayers.Map('map');
             var gmap = new OpenLayers.Layer.Google("GMaps",{type:
 G_HYBRID_MAP, numZoomLevels: 20});
             map.addLayer(gmap);
             map.setCenter(new OpenLayers.LonLat(0,0), 15);
             map.setCenter(new OpenLayers.LonLat(39, 85), 5);
         </script>
     </meta> </body>
 </html>
Ticket URL: <http://trac.openlayers.org/ticket/3484#comment:2>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
