[OpenLayers-Trac] [OpenLayers] #3492: GMLv3 doesn’t show or update GeometryCollection
OpenLayers trac-20090302 at openlayers.org
Thu Sep 8 10:48:03 EDT 2011
 Reporter:  lsmtti                                                |       Owner:  tschaub
     Type:  bug                                                   |      Status:  new
 Priority:  minor                                                 |   Milestone:  2.12 Release
Component:  Format.GML                                            |     Version:  2.11 RC3
 Keywords:  GeometryCollection, Multigeometry, update, GML3, GML  |       State:
 I’m using an Oracle 10G database on WS2003 with Geoserver nightly build
 from trunk (geoserver-trunk-2011-09-05-bin.zip) (we used this version
 because there is a problem in stable version) on windows XP. I was doing
 some tests with WFS-T 1.1.0 with GML 3, on a windows xp host machine with
 firefox and found out that OpenLayers doesn’t show or update
 GeometryCollection. That arises because  GML v3 isn't dealing correctly
 with the Geometry.Collection. OpenLayers is expecting erroneous it to be
 GeometryCollection when it should be MultiGeometry as stated in the spec
 of GML v3. I’ve made a patch to correct this and now in our scenario we
 can use WFS-T to show update and insert geometries when those geometries
 are GeometryCollection. I would like you to review it and add this
 correction to OpenLayers if possible, or a better one that fixes the
 problem.
 To reproduce the problem you must have a GeometryCollection stored in a
 Database (in our case Oracle) use a Open Geospatial Consortium WFS-T
 compliant server (in our case Geoserver 2011-09-05 build).
 1 - Declare a vector layer in open layers expecting the GML3 output (from
 geoserver)
      ''var teste3BaseWFS = new OpenLayers.Layer.Vector("TESTE3", {
      strategies: [new OpenLayers.Strategy.BBOX(), saveStrategy],
      protocol: new OpenLayers.Protocol.WFS({
          version: "1.1.0",
         srsName: "EPSG:27493",
         url: "http://localhost:8080/geoserver/wfs",
         featureNS :  "http://localhost:8080/geoserver",
         featureType: "TESTE2_BEMPORTUARIO",
         outputFormat: "GML3",
         geometryName: "GEOMETRY"
 2 - Then Geoserver will generate the following GML so that OpenLayers can
 show up the geometries
 ''<?xml version="1.0" encoding="UTF-8"?>
 <wfs:FeatureCollection numberOfFeatures="0"
 timeStamp="2011-09-05T14:08:21.187+01:00"
 xsi:schemaLocation="http://localhost:8080/geoserver
 http://localhost:8080/geoserver/wfs?service=WFS&amp;version=1.1.0&amp;request=DescribeFeatureType&amp;typeName=O3Port%3ATESTE2_BEMPORTUARIO
 http://www.opengis.net/wfs
 http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd"
 xmlns:ogc="http://www.opengis.net/ogc" xmlns:tiger="http://www.census.gov"
 xmlns:cite="http://www.opengeospatial.net/cite"
 xmlns:nurc="http://www.nurc.nato.int" xmlns:sde="http://geoserver.sf.net"
 xmlns:wfs="http://www.opengis.net/wfs"
 xmlns:topp="http://www.openplans.org/topp"
 xmlns:O3Port="http://localhost:8080/geoserver"
 xmlns:it.geosolutions="http://www.geo-solutions.it"
 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
 xmlns:sf="http://www.openplans.org/spearfish"
 xmlns:ows="http://www.opengis.net/ows"
 xmlns:gml="http://www.opengis.net/gml"
 xmlns:xlink="http://www.w3.org/1999/xlink">
   <gml:featureMembers>
     <O3Port:TESTE2_BEMPORTUARIO gml:id="TESTE2_BEMPORTUARIO.30519">
       <O3Port:GEOMETRY>
         <gml:MultiGeometry srsDimension="2"
 srsName="http://www.opengis.net/gml/srs/epsg.xml#27493">
           <gml:geometryMember>
             <gml:LineString>
               <gml:posList>-47103.3946020567 169627.5381311
 -47053.0385691367 169484.4209849</gml:posList>
             </gml:LineString>
           </gml:geometryMember>
             <gml:LineString>
               <gml:posList>-47119.2965071867 169375.75796649
 -46986.8537496867 169432.76120727</gml:posList>
             </gml:LineString>
             <gml:Polygon>
               <gml:exterior>
                 <gml:LinearRing>
                   <gml:posList>-47283.6161935567 169349.25479127
 -47185.5544452367 169357.20574384 -47103.3946020567 169394.31018915
 -47113.9958721467 169471.16939729 -47283.6161935567
 169349.25479127</gml:posList>
                 </gml:LinearRing>
               </gml:exterior>
             </gml:Polygon>
             <gml:Polygon>
               <gml:exterior>
                 <gml:LinearRing>
                   <gml:posList>-47238.5607956867 169481.77066738
 -47113.9958721467 169518.87511269 -47116.6461896667 169585.13305075
 -47209.4073029367 169601.03495588 -47238.5607956867
 169481.77066738</gml:posList>
                 </gml:LinearRing>
               </gml:exterior>
             </gml:Polygon>
         </gml:MultiGeometry>
       </O3Port:GEOMETRY>
     </O3Port:TESTE2_BEMPORTUARIO>
   </gml:featureMembers>
 </wfs:FeatureCollection>''
 3-  It does not show the geometries of the type GeometryCollection, then
 change the outputFormat  for GML2 to testing if the GeometryCollection is
 shown.
     '' var teste3BaseWFS = new OpenLayers.Layer.Vector("TESTE3", {
         version: "1.1.0",
         outputFormat: "GML2",
 4- Now OpenLayers can display the geometry, since it is receiving an GML2
 format.
 5 - When we try to edit and save the geometryCollection, GeoServer will
 generate an error since OpenLayers is generating an GML3 response and
 erroneous uses GeometryCollection instead of MultiGeometry. I have seen in
 the GML 3 specification what is the the name of tag for representation of
 GeometryCollection and that name is MultiGeometry. The following WFS
 transaction is generated by OpenLayers.
 ''<wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
 version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
 http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
   <wfs:Update typeName="feature:TESTE2_BEMPORTUARIO"
 xmlns:feature="http://localhost:8070/geoserver">
     <wfs:Property>
       <wfs:Name>GEOMETRY</wfs:Name>
       <wfs:Value>
         <gml:GeometryCollection xmlns:gml="http://www.opengis.net/gml"
 srsName="EPSG:27493">
             <gml:LineString srsName="EPSG:27493">
               <gml:posList>-46991.12771677839 169596.48558836358
 -46988.54482653 169450.97978503</gml:posList>
             </gml:LineString>
               <gml:posList>-47054.80276458 169342.31676662 -46922.36000708
 169399.3200074</gml:posList>
             </gml:LineString>
             <gml:Polygon srsName="EPSG:27493">
               <gml:exterior>
                 <gml:LinearRing>
                   <gml:posList>-47219.12245095 169315.8135914
 -47121.06070263 169323.76454397 -47038.90085945 169360.86898928
 -47049.50212954 169437.72819742 -47219.12245095
 169315.8135914</gml:posList>
                 </gml:LinearRing>
               </gml:exterior>
             </gml:Polygon>
               <gml:exterior>
                 <gml:LinearRing>
                   <gml:posList>-47174.06705308 169448.32946751
 -47049.50212954 169485.43391282 -47052.15244706 169551.69185088
 -47144.91356033 169567.59375601 -47174.06705308
 169448.32946751</gml:posList>
                 </gml:LinearRing>
               </gml:exterior>
             </gml:Polygon>
         </gml:GeometryCollection>
       </wfs:Value>
     </wfs:Property>
     <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
       <ogc:FeatureId fid="TESTE2_BEMPORTUARIO.30519"/>
     </ogc:Filter>
   </wfs:Update>
 </wfs:Transaction>''
 6 - After applying the patch OpenLayers will show well the geometry
 collections and will generate the following WFS transaction (wich is the
 correct one).
     <wfs:Property>
       <wfs:Value>
         <gml:MultiGeometry xmlns:gml="http://www.opengis.net/gml"
             </gml:LineString>
             </gml:LineString>
               <gml:exterior>
                 <gml:LinearRing>
                 </gml:LinearRing>
               </gml:exterior>
             </gml:Polygon>
               <gml:exterior>
                 <gml:LinearRing>
                 </gml:LinearRing>
               </gml:exterior>
             </gml:Polygon>
         </gml:MultiGeometry >
       </wfs:Value>
     </wfs:Property>
     </ogc:Filter>
   </wfs:Update>
 Thanks in advance Luis Morais
Ticket URL: <http://trac.openlayers.org/ticket/3492>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
