[OpenLayers-Trac] [OpenLayers] #3499: OpenLayers Custom Build
_getScriptLocation not working properly
trac-20090302 at openlayers.org
Tue Sep 13 07:22:54 EDT 2011
#3499: OpenLayers Custom Build _getScriptLocation not working properly
Reporter: ckreuzbe | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.12 Release
Component: general | Version: 2.10
Keywords: images getScriptLocation custom build filename different | State:
OpenLayers/SingleFile.js, Line 27:
_getScriptLocation: (function() {
var r = new RegExp("(^|(.*?\\/))(OpenLayers\.js)(\\?|$)"),
This function tries to find the OpenLayers.js file in the html elements
that are including javascript resources.
However, when trying to do a custom build like this:
python build.py -c closure mainMap ../OpenLayers-mainMap.js
(yes the closer compiler is installed properly)
while mainMap.cfg looks like this:
[first]
[last]
[include]
OpenLayers/Control.js
OpenLayers/Control/ZoomPanel.js
OpenLayers/Control/MousePosition.js
OpenLayers/Control/Navigation.js
OpenLayers/Control/Permalink.js
OpenLayers/Control/Attribution.js
OpenLayers/Control/PanZoomBar.js
OpenLayers/Control/SelectFeature.js
OpenLayers/Control/NavigationHistory.js
OpenLayers/Rule.js
OpenLayers/Icon.js
OpenLayers/Marker.js
OpenLayers/Projection.js
OpenLayers/Feature/Vector.js
OpenLayers/Feature/WFS.js
OpenLayers/Format/JSON.js
OpenLayers/Format/GeoJSON.js
OpenLayers/Filter.js
OpenLayers/Filter/FeatureId.js
OpenLayers/Filter/Function.js
OpenLayers/Filter/Spatial.js
OpenLayers/Protocol/HTTP.js
OpenLayers/Protocol/WFS.js
OpenLayers/Protocol/WFS/v1_0_0.js
OpenLayers/Strategy/Fixed.js
OpenLayers/Map.js
OpenLayers/Renderer/SVG.js
OpenLayers/Renderer/VML.js
OpenLayers/Renderer/Canvas.js
OpenLayers/Layer.js
OpenLayers/Layer/SphericalMercator.js
OpenLayers/Layer/XYZ.js
OpenLayers/Layer/WMS.js
OpenLayers/Layer/Vector.js
OpenLayers/Layer/Markers.js
OpenLayers/Layer/TMS.js
OpenLayers/Layer/Google/v3.js
[exclude]
you will not see any control images on your website, because
getScriptLocation will NOT find OpenLayers.js at all (because the file is
called OpenLayers-mainMap.js).
One might ask: Why do you not just rename OpenLayers-mainMap.js to
OpenLayers.js?
Because I want to have a few different custom build profiles.
so yeah, I could start playing around with symbolic links and other hacks,
but that's not the point.
The library should be able to find itself easily. I do understand that it
is not possible to support every possible filename, however it is possible
to come up with a clever way of how to do this.
a) look for OpenLayers*.js
b) look for OpenLayers.js first, if you can't find it, look for
OpenLayers*.js (so you will not break compatibility)
c) give the user a way to specify the actual javascript filename in the
source code (e.g. OpenLayers.ScriptFileName='OpenLayers-mainMap.js'; ),
and, if possible, include this in the python build script so it sets the
default value according to the output-file-name option of build.py.
While option a (and maybe even b) might break compability with other
things that are out there, option c should not break anything, and
therefor I highly recommend implementing option c).
ideas, objections, other solutions that I have not mentioned?
Ticket URL: <http://trac.openlayers.org/ticket/3499>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
