[OpenLayers-Trac] Re: [OpenLayers] #3499: OpenLayers Custom Build _getScriptLocation not working properly
OpenLayers trac-20090302 at openlayers.org
Tue Sep 13 10:53:32 EDT 2011
 Reporter:  ckreuzbe                                                  |       Owner:
     Type:  bug                                                       |      Status:  new
 Priority:  minor                                                     |   Milestone:  2.12 Release
Component:  general                                                   |     Version:  2.10
 Keywords:  images getScriptLocation custom build filename different  |       State:  Review
Comment(by jorix):
 I think this is not a bug (is a feature), this is normal behavior. The
 name should only be {{{OpenLayers.js}}}.
  In my case I have the same problem, since I have several compilations:
 lite and custom.
 To change the behavior just add after:
 <script src="/Your-location-for-OpenLayers/OpenLayers-mainMap.js"
 type="text/javascript"></script>
 this line:
 <script>
 OpenLayers._getScriptLocation = function(){return "/Your-location-for-
 OpenLayers/"};
 </script>
 But this is not a "medicine" supported by the APIs. It would be nice to be
 so!
 > c) give the user a way to specify the actual javascript filename in the
 source code (e.g. !OpenLayers.ScriptFileName='!OpenLayers-mainMap.js'; ),
 and, if possible, include this in the python build script so it sets the
 default value according to the output-file-name option of build.py.
 instead of {{{OpenLayers.ScriptFileName='OpenLayers-mainMap.js';}}} I
 like:
 OpenLayers.setScriptLocation="/Your-location-for-OpenLayers/";
 NOTE: I'm not a member of the team OpenLayers.
Ticket URL: <http://trac.openlayers.org/ticket/3499#comment:2>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
