[OpenLayers-Trac] [OpenLayers] #3504: Build: Allow compressed code
out of "lib" in conjunction with OpenLayers
trac-20090302 at openlayers.org
Wed Sep 14 12:09:35 EDT 2011
#3504: Build: Allow compressed code out of "lib" in conjunction with OpenLayers
Reporter: jorix | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: general | Version: 2.11 RC3
Keywords: | State:
Sometimes to customize !OpenLayers is required to make some changes in the
sources or additional coding.
I think (this is my case) it's more safe put these changes out of the
location of !OpenLayers, but this forces to create two compressed files
and also directive {{{@requires}}} not working on altered code.
The proposed patch allows specify file names in {{{*.cfg}}} from other
locations (and warning if the file does not exist)
Implementation: I used actual code in {{{## Import file source code}}} in
{{{importFiles}}} method. First for each clause {{{[first] [last]
[include]}}} and lastly for {{{os.walk}}} files (remaining files).
NOTE: {{{Import remaining files}}} can be skipped if exists
{{{[include]}}}, but I have not changed for no further changes.
Ticket URL: <http://trac.openlayers.org/ticket/3504>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
